DirtRidinz71
I am running a stock K5 rear driveshaft in my 92 GMC (around 8" of lift) with a GM 3R/S44 u joint up front and a 3R to a Ford 1330 BC (Big cups) conversion u joint at the rear diff (sterling 10.25). The problem is I have to special order the u-joints, around a 2 month wait, they are pricey and with the angle don't have a long life.
I am running at near max angle for the 1330 u joint and had to grind the front slip yoke and drive shaft to clear without binding at full drop.
A super short SYE would be the best option but out of the budget so my next best idea would be to upgrade to a 1410 slip yoke, drivershaft and rear pinion yoke. The 1410 claims to allow for more angle and is much beefier then the 3R or 1330.
Has anyone done this with a stock driveline on a lifted K5? Even though the u-joint will run at the angle, did the yokes/ears need to be grinded down to clear without binding?
