RoTuN
Registered Member
Just wondering if anyone has come up with a solution to the inner hub seals being exposed after doing the disc conversion........................
Yeah, I realize the wheel will shield alot of it but I also know the OEM design has the backing plate to protect it from the elements so it is only subject to brake dust. I'm concerned about sand, rocks, mud, snow, ice, etc., especially ice build up with where I will be going. Would hate to have to replace a seal after every trip.
Anybody ever have issues with debris destroying these seals?
I am in the middle of a pretty simple solution, will post if it works.
Will front axle back plate things fit?![]()
I did think about that but the calipers shot that to hell...
Could they be modified in some way? cut up where they dont fit?
What if you were to take everything off the spindle and then take a cylinder that would fit over the seal and into the rotor a little, weld it to a plate that bolts to those 4 bolts, drill a hole or two in the bottom for water and junk to get out, maybe one on top so that if you really get crud in there a hose could blow junk out. Done![]()
The first one is a 2" storm collar (Oatey?)
Second is Fernco, part # P1056-42
Had to heat up the 2" side really good and grease the stub to get it on, nice tight fit even before the clamp went on.
