14bff; Detroit Locker Interchangeable no matter gear ratio?
Kay86K5
Emmett, ID
Did a little research, but don't have much time cause at work, but wondering if the Detroit locker is interchangeable no matter what gear ratio is in a 14bff? I know the carriers are different (4.10 and down vs. 4.56 and up). But if you have a Detroit locker current in a 4.56 carrier, will that Detroit fit right into a 4.10 carrier?
Yep, I just answered my own question :haha:
http://eastcoastgearsupply.com/i-129787-gm-10-5-14-bolt-detroit-locker-225s10-fits-open-carrier.html
In the description it says fits all ratios. This should be good cause my current 89 Crew Cab has 4.10 gears and my crawler I have 4.56 gears (with a Detroit in the rear). I want to swap the 4.56's into my crew cab, take the Detroit out and put into the 4.10 carrier, and then order 5.38's for my crawler....that way I get the lower gears I want in my crawler, and a little lower gears in my tow rig to run the tire size I want on that thing....and all I have to do is purchase 5.38 gears :burnout:
Hard to find 5.13s or 5.38 non thick isn't it
Lol
From my reading, as long as you have the 4.10 and down carrier you can run the thick 5.38's correct?
Edit: Ah, I see what you did there, haha
