14bff disk conversion questions
Seventy4Blazer
3/4 ton status
Escondido, CA
what all do i need other than brackets for a 14bolt disk conversion? will D44 calipers work?
and what else? where do i bolt the rotor up? in the back just like the drum? any write ups on this subject?
is 20 dollars a caliper a good price?
Grant
1974 Chevy Blazer Cheyanne. but it is on 33's now, with saggy old springs. i am in Yuma Arizona if ya got any parts for me.
If you go to my for sale ad " i also have 14 bolt disk brake brackets" on page 3 or so and find the post by prediator he did a great write up on his install. It includes everything you need and a price list. Check it out.
<P ID="edit"><FONT class="small">Edited by DERBINATOR on 02/19/02 05:55 AM.</FONT></P>
<font color=blue>The rotor goes behind the hub just like the drum does, and the studs are pressed in from behind. You can use D44 calipers, and $20 each sounds about right
misfits backing plates are for sale again in the for sale section, and he does great work.
<font color=blue> Jeff - may the force be with you</font color=blue>
<a target="_blank" href=http://coloradok5.com/gallery/Jeffs-Stuff>link to k5's</a>
