I have a Cab&Chassis 14bff axle with 4.56 gears and an open diff in it. I also have a 79 3/4 14bff with 3.73 and gov lock in it. I want the 4.56's to put in the 3/4t axle housing to put under my Blazer.
1)Can I use the whole carrier and diff. assy from the C&C axle and properly set it up to the 3/4t housing?
2)I also want to add a Detroit to the C&C carrier, which should work being that it is open already right?
3)The 4.56 carrier will have to be set up to the 3/4t housing because it is a different housing right?
4)Will the axleshafts out of the 3/4t housing work without modification in the C&C diff with the addition of the Detroit?
5)I know the 3/4t housing is a bolt in, I will be adding a T400/205 combo when I do this, so I'll pretty much have to build a new driveshaft right?
I think it has a 350/203 in it now.
6)I will be adding a 6-8" lift to this project, will it be advantageous to adjust the pinion angle at this time?
7)Give me some ideas on lift spring kits or other mods to get the 6-8" lift, like the shackle flip etc.
thanks, Zim
thanks, Zim
, sorry, and if someone else corrects me then we will both have learned something new today
