Hossbaby50
3/4 ton status
to find a govlock you should look at people parting trucks out in your area or the junkyard. Govlock axles are less desired then open carrier axles so the price is usually pretty cheap. You just need to find a 14bff rear axle with your current gear ratio in it and a govlock and you should be all set. Put some new brakes on the axle or swap on your old ones, check the wheel bearings, and fill the diff with some clean fluid and your ready to go.
Harley
Harley
