14bff rear disc clearance w/ wheels?
i have to grind my rear calipers, which are from a 3/4 ton front end and the RuffStuff brackets. I'm also running the 3/4 ton rotors.. the wheels i run are 15x12 with 4" back spacing. I was going to run a spacer to make the wms the same as the front which would also allow me to not hit the calipers, but as of rite now, i have to grind them
15x8 Eatons on 14B disc conversion with no problems. D60 front did take a little time to fit to wheels.
I running 15x12 steel wheels with 2.75 backspacing and I didn't have to grind anything. Though they only clear by millimeters
