14bsf to 14bff driveshaft ? **NEW u-bolt ?**
JIMs70K25
Chesapeake, VA
Going to purchase a 14BFF to replace the 14BSF in my burb, How much shorter will my driveshaft need to be? or How much lift should I go with to use the stock driveshaft?
I'm going to get the 14BFF this weekend, next question and I beleive I know the answer, Will my u-bolts/plate work? I believe it will not and I'll need new u-bolts and spring plates. confirm this please.
IIRC, it might be something on the order of 1-2" or so shorter for the 14bff
When I went to the 14ff from the 14sf I used the same driveshaft with no mods. They have the same 1350 yokes
Pinion yoke is about 1" further forward on the 14SF than 10 bolt, sounds like the 14FF and SF are about the same in that regard, makes sense.
axle tube diameter is 3-3/8" on a FF, but you should get new ubolts regardless, once they have been torqued, they will not hold again, and can loosen up over time :eek1:
Yes the u-bolts will work, same tube diameter.
I've re-used the u-bolts for the couple of axles I've installed in my truck, whenever I'm doing maintenance those are one of the things I check, they've never loosened up on me. I made sure to keep the factory nuts and washer that is installed, they seem to have a different color about them for some reason...
