UPDATE INFO :::::well it came back. broken studs again. found a worn duelly hub on it that was missed before but in normal working conditions would not afect it. the ridge that centers rim bore on hub was worn off in 1 out of 4 spots and 2/3rds off in another.
then we got a good used replacement. installed it . then test drove it with a plan. went to local truck scale and got it weighed. frt gvw is 4000 act is 3880. rear gvw is 7000 act is 8990. total is 10,000 act is 12,870. and he removed 400-500 lbs when at shop to do work out of local truck.
he is well over by 1.5 tons of max gvw rating. what is your info on this now we know what the real world info is. ? ?
at work we have a customer with a p chassie van. full aluminum body like giant bread truck. he has this thing chuck full of heating/electrical/plumbing type stuff. powered by 350 and 4l80-e.
i have asked him before and he said its in the 11500lbs range over a scale.
my question is this to much weight for a daily driver that goes 300-400 miles per trip all day and some times 2-3 states away.
reason i ask is he is having problems keeping studs on the pass side duels. he has had new studs installed on both sides and has new rims also. well today he called 3.5 hrs away and rr studs gone again . . . . . . and 120 is tourqe spec on lug nuts.
what is the gm spec on the daily loads for this axle. and what real world use have you done every day with out fauler. i need to know to help back me up as he is going to try and blame me on this.
i know the tourqe specs on these axles and use them every time ..
at my wits end here help me.
? salsbery and banjo style never heard these terms before .?
