14FF bearing hubs
thatK30guy
1 ton status
Have brand new studs installed, was gonna use these for a trailer minus the brake parts, etc., hence the short studs.
Outer wheel bearings are still inside and highly recommend replacing these. Hubs would need cleaning as they've been sitting for years and have a little surface rust on them along with a little bit of grease/oil.
Perfect for replacements, spares or to swap onto your D70HD to give it a wider matching track as a DRW D60 front.
$60 for the pair plus shipping on your dime. Would these fit in a large flat rate box via USPS?
You saying that 14bff hubs fit on a D70HD spindle?
Yep, few guys have done this swap.
no to large flat rate box . :doah:
funny thing is i have 2 pairs 1 srw and 1 drw in my garage for this idea my self and i have the tubes with spindles from cut up c&c axle also to make axle from .
Id be interested in these if shipping doesn't kill it. Would you mind getting a shipping quote to 96114?
No prob. Let me look for a sturdy box tomorrow at work.
