SCOOBYDANNN
tack weld the perches where you "think" they will go. put it in place. if it works glue it up. if not---break the tacks and rotate to where it makes you happy.
SCOOBYDANNN said:tack weld the perches where you "think" they will go. put it in place. if it works glue it up. if not---break the tacks and rotate to where it makes you happy.
aparently I'm good at thatSCOOBYDANNN said:aparently I'm good at that
KidJethro said:Clean that damn thing up and paint it.![]()
ryan22re said:I hadn't planned on painting it. Or cleaning it up. At all. I figure, I'll fix the leaks and let it heal itself.
GotLabs said:The diff housing is in serious need of some oven cleaner yo. No way that "thing" would be in my garage, all greasy and masculine.
