whoops I knew that didnt sound right. yea I also got a pair of 1410 u-bolt stylestRustyK5 said:Strap style brings the suck. it doesn't look good to me James...I agree it appears someone fragged a U-joint cup and it beat the yoke up a bit.
NWF has the 1350 or 1410 yokes modified to run the u-bolt style and they're pretty reasonable. I run U-bolt style 1410's front and rear.
Rene
jiminycricket said:Thanks gents, I may as well get a u-bolt style from NWF.
Having no prior 14 bolt yoke knowledge what's the procedure for swapping that out, any crush sleeve or other problems to consider?
5280k5 said:Nope, all I do usually is just mark the pinion to nut with a center punch so you know the nut is back where you started. There is a rotating torque in inch pounds if you want to be technical. Are you going with a bigger sized joint?
5280k5 said:You see the way I drive James, I NEED it![]()
5280k5 said:We'll see what happens this year with the new big rubber, might have to tone it down a little to keep the drivetrain together......
or maybe not![]()
On a side note, did you get a chance to call my buddy 'bout your TBI problem?
It's the cheapest fix!here's a little reading material for you.jiminycricket said:Thanks gents, I may as well get a u-bolt style from NWF.
