15" wheels with a dana 60....how is it done
howdiy
Fl
The search function really doesn't work well so I'll just ask
sorry bout the mud
picture.php
picture.php
grind the calipers about 1/16" or so (takes ALOT of trial fit and removal) or get rims with the proper offset to clear the edge of the caliper...guess i need to go measure it...
grind the calipers. the less backspacing the easier it is. 2.5" requires no grinding, 4.25" requires alot. ive personally run 15x10's with 3" BS and i had to grind a little bit, but nothing too serious.
not sure...went outside to measure em but couldnt find a tape measure...$5000 worth of tools in the garage and i dont have a f'n tape rmeasure...i'll get one SOON and post measurements and take some better pics...
2.5 is easy and i think best.
3.0ish is good trade off for amount of grinding.
4.25 i would never grind that much off the brake parts and plan on running the street.
i got 3.5 backspacing on my 15s. i made sure to leave one rim without a tire cause your going to be putting that rim on and off that caliper like 50 times while grinding and its alot easier without a tire
Oh so I did need the calipers, they're freaking huge
This seems easy enough
Thanks guys
I think I'll try 3.5 BS, I don't want the tires out too far, But I'll take some measurements and try to go with the least amount necessary
