16x10 or 16.5x9.75?
MudFrog
Daleville, Va
Which should I go with when I do my axle swap? I will run a chrome wheel. There really isn't much difference in price as far as tires go. But I see more tire sizes available in 16.5". Should there be anything else I'm aware of when deciding? How bout backspacing on each wheel?
89 K5 Silverado
<A target="_blank" HREF=http://mudfrog.coloradok5.com>http://mudfrog.coloradok5.com</A>
If it's a daily driver/show truck either will work but there are more tire choices (I think) for the 16.5 rim, but if you are going to wheel and/or air down your tires, the 16 is the best way to go because the 16.5 has no beadlocks.
If you are planning on airing down when wheeling go with the 16" rims. They will hold a bead at much lower presure then the 16.5" rims will.
See Ya,
Keith
<font color=green>Born to Drive My K5</font color=green>
I'd go with a 16 over a 16.5 any day because of the safety bead lip.
-- Mike
If you don't mind using some mid-70's stock chevy wheels that are 16.5-you could air down because they do have a safety bead. All after market 16.5 wheels don't.
