| STEEL BENDING STRENGTH INCREASE | ||||||||||
| Material Thickness | Material Thickness Decimal | Steel Weight by S.F. lbs. | 14-gauge (.075) | 12-gauge (.106) | 11-gauge (.120) | 10-gauge (.135) | 3/16" (.188) | 1/4" (.250) | 3/8" (.375) | 1/2" (.500) |
| 14-gauge | 0.075 | 3.125 | 2.86x | 4.15x | 5.9x | 15.9x | 37.5x | 126.5x | 299.9x | |
| 12-gauge | 0.106 | 4.375 | .35x | 1.45x | 2.06x | 5.59x | 13.12x | 44.3x | 105.0x | |
| 11-gauge | 0.120 | 5.00 | .24x | .69x | 1.42x | 3.85x | 9.04x | 30.5x | 72.3x | |
| 10-gauge | 0.135 | 5.625 | .17x | .48x | .70x | 2.7x | 6.35x | 20.25x | 49.9x | |
| 3/16" | 0.188 | 7.66 | .06x | .18x | .26x | .39x | 2.35x | 7.04x | 18.8x | |
| 1/4" | 0.250 | 10.21 | .03x | .08x | .11x | .16x | .43x | 3.38x | 8.0x | |
| 3/8" | 0.375 | 15.32 | .01x | .02x | .03x | .05x | .13x | .30x | 2.37x | |
| 1/2" | 0.500 | 20.42 | .003x | .01x | .015x | .02x | .05x | .12x | .42x |
In our defense, after 6 months of no updates, the build might be dead!
There’s 8 more minutes of sunshine everyday on this side of the borderI did spend hours cleaning/scraping and undercoating the inner floor boards and inner/outer firewall.
Guess I forgot to post pics/progress. I believe I have the abs delete figured out as well. I probably will not have time to work on it until after Tri State. Not enough sunshine lately for some reason.
Soooooo are the Ford hubcaps for sale? lol Only thing I came here to ask.
Yep, 466 with an Allison trans. Truck is a 2007 and was purchased thru a local Sheriffs sale. Looks like it was robbed of various parts then scrap monkeys went thru and cut almost all of the wiring out of it. The Sheriffs Dept sold on a bill of sale and voided the title with the state so one way or the other it was going to have to be "recabbed" Bed is actually in really good shape and the wheel lift appears to have very little use.DT466? What transmission?
In a perfect world I am hoping to find a pre emissions low mile International to put this bed on.Just a crappy egr dt466. Not too big of a loss there. The Allison will be worth something.
I really like the mid 90s dt466. It's the mechanical one with the aluminum valve cover and aluminum front cover just like the dt466e but with a mechanical injection pump still. The dt466e is a great engine but you gotta have someone with International software or a decent aftermarket setup to do anything. I have shopped around a bunch and if you can find an ex-fire truck they got the highest horsepower engines. A dt530 or ht530 would be sweet.In a perfect world I am hoping to find a pre emissions low mile International to put this bed on.
I had a 466E in a 98 or so 4300 series years ago that I really liked.
Any idea on what years are best or to stay away from? Do the 466E's pull stronger then the old mechanical injector 466s?
