1966 Chevy C20
I haven't done anything with the rear axle. I just keep the speed where it makes the least noise. :rotfl: I really wish you could buy a rebuild kit for the axle in it. Aside from that, I've been passively watching for a "new" axle. There's a small window of years, maybe just 67 & 68, that you could get Dana 60 rear axle with the coil spring rear suspension; that's what I'd really like to find. Otherwise eventually I'll swap in another axle. If the situation is right, I'd go with 1/2 ton, but I'm really hoping to keep it as original as reasonably possible.
I have a SM465 with a Gear Vendors overdrive that I hope to swap in at some point in the future. I sometimes wonder if the noise I hear might be from the transmission so I'll probably swap the SM465 in before I do a rear axle.
Why downgrade?
If it doesn't haul any weight, it would be easier to get decent gears as well as tires that ride better. IMO.
He is hauling stuff with the 1/2 ton '73, and has a 2500 work truck and others for heavy stuff. But apparently @mrk5 has already considered this.
