1968 Camaro deluxe 327/4sp
yellow.dawg
Kokomo, Indiana
Very nice unmolested camaro. It came from Cali and I was told by the dealer I got it from it has never been painted. It does need paint as it starting to chip and crack, but shines and look good 5 feet away. No rust with exception to some surface on the frame. Has factory A/c, cali smog that works (taken off) a muncie 4 speed, 14 rallys with redline tires. I rebuilt the engine last summer and it has maybe 500 miles on it. Bored .030 over, 9.2-1 cr, hyper pistons, comp cam, double hump heads with stainless valves, edelbrock 4bbl 600, functional cowl induction. New 2.25 exhaust with flowmasters, new stage 1 clutch and reground flywheel, new heater core. I belive the A/C will work with a vacuum as it hissed when i loosened a line. I have every part that was original ie hood and carb and smog. Interior is pristine with exception to the shifter bezel, it needs a new one as its warped. I also have a new 3.73 10 bolt posi and a drisk brake setup for this and will include with asking price. You dont find them like this at all. Located in Kokomo Indiana. Call 8158145822.. Asking $20,000.
