WA 1969 3/4 ton 4x4 Chevy
k2-k5
Vancouver, WA
Front.jpg IMG_7537.JPG IMG_7444.JPG IMG_7799.JPG IMG_7806.JPG 1969 3/4 ton K20 4x4 Chevrolet
Wheel base shortened 16 inches (111" wheel base) and another eight inches removed from the rear frame.
454 Big Block, TH350 transmission and NP205 transfer case
Dana 44 HD front axle, 4.10 gears with ARB air locker and disc brakes
Dana 60 rear axle, 4.10 gears with ARB air locker and disc brakes
BFG 35"x12.50 KM1s on steel wheels almost new
Winch, Garwood PTO 20,000 Lb. rated from a Deuce and a half with 400 feet of 7/16" cable that can run out the front or the rear of the truck.
Combined total of 55 gallons of fuel storage between the factory 20 gallon behind the seat tank and a custom fuel cell mounted to the bed.
Custom built steel bed, cab guard, sliders and bumpers
Custom built tool box (is removable) that has locking rear access and the full length of the bed
ORD custom built front springs (flexy), shackles, and shackle flip kit with less than 500 miles on them.
New Ranch 9000 adjustable shocks with less than 100 miles on then
New front driveline with less than 500 miles
New master cylinder and proportioning valve
Dual 12" 5w Cree led light bars on the front that are wired in with the high beam circuit Side and rear led lighting LED maker, reverse and brake lights
Removable mud flaps
New heavy duty floor mat with insulation
New seat cover, new headliner
CB radio and stereo
$7,500.00
Located in Vancouver, WA
Depends what wheelbase you want to end up with. Short bed may be fairly easy. A long bed might be easier just to use a LB frame.
Hmmm, rob liquer store, then 7 eleven, albertsons...
Hmmm, I will give you $9,000,.
I suck at haggling, but I've been known to orchestrate a number of well thought out heists.
