7387chevynut
Registered Member
Hi all,
I recently picked up a 3spd hooked to a Dana 20 out of a 71 blazer. I am familiar with when it was used by GM and its odd ball J style shift pattern.
But after i got it home, and I was messing around with it and noticed that I can rotate the lever assembly 360% while its still mounted inside its ball socket type housing.
Is this normal, or is there somthing worn out inside the ball socket housing?
Also I wanted to separate the 3spd from the T-case adaptor............and the trans came loose about an inch, and then I noticed some of the internal gears were coming loose...........what gives???..........is there a C-clip holding something on?.................I've taken apart SM465/NP205's before, with no problem.....................but this 3spd/Dana 20 is a wild little animal I've never delt with before.
