I have a 13psi on it now.l replacing the rusty 19psi. I saw this from gooooooogling that 18psi is maximum recommend psi for small blocks
The radiator company recommends 19psi with their radiator. I assume that can very depending on the engine you're running.
So, how will I know if 13psi isn't correct and maybe going upto 16psi is better or if the manufacturers 19psi recommendation is what is ideal for this small block? And if 18psi is the maximum psi for a small block why do they recommend 19psi?
I'm going to get a 16psi cap today and see what happens. Granted the heat out here isn't helping and as
@6872xtc noted from my comments, my heat gun didn't notice anything crazy heat wise and was contrary to what my temp gauge in the cluster was stating.
The only or main reason this is dragging on, as per my usual in threads, is for me to learn about radiator caps and the function in the vehicles system. And also what proper psi does.
While 19psi seemed fine, I'm replacing it because it's all gunked and I think 16psi will hopefully be better. I don't know.
Some info pertinent to the topic, at least for me:
Radiator cap function
