well I am an idiot and missed one rocker when swapping on the Harland sharps. Lifters quiet, exhaust leaks, not so much. This pair of headers is a pain in my butt. Why are all the header gaskets made for such a big port? These only have a 1.635x1.635 opening yet the gasket is 1.88x1.88 which is half way past the weld on the flange.
The gaskets that come with headers are crap, I don't even bother with them.
If your headers have the protruding welded flange, I like the sandwiched aluminum header gaskets.
If they are ground flat on the flange and the flange is not real thick (only 1/4 or 5/16"), I like the percys carbon, or possibly embossed copper.
If you have flat flanges that are thick, 3/8" or thicker, the stainless gaskets can also work well.
All of them, have to fit of course, most gasket makers have several sizes and shapes for BBC and SBC.
Also, I always retorque them after it cools down for the first several heat cycles. Once they stop moving, could be 2 or 3 times, could be 6, then you should be good to go for a long time, over a decade if it's right.
