Is it missing an air dam under the radiator to help the air go up through it instead of under it? That can cause them to run hot at highway speeds too.
Thank you! The only radiator shop we had around here closed up a couple of years ago and that guy wasn't super reliable; he just stayed in business because he was the only show in town.Get that one rodded out. If you can find a radiator shop.
Glad it's running and Patrick is enjoying. Sounded good what I could hear.
Great job Dad
I know the GS models had a front spoiler deal, but I don't think the base models did.Is it missing an air dam under the radiator to help the air go up through it instead of under it? That can cause them to run hot at highway speeds too.
Yeah, he hasn't learned not to jam the wheel against the stop.was that the power steering making that noise ?
I have buckets full of them. They look the same as the screws used to hold stuff to the firewall (ground strap, heater box, etc) on squarebody trucks. Typically, 7/16 hex for the head in the 70s and 10mm hex in the 80s.The 2 screws with X's thru them I'm 90% certain are substitutes. The one is a phillips and the other required a 10mm socket.
There are also some with a 3/8" hex. Those started getting replaced with 10 mm around 1975 from what I have seen.Now I'm questioning if I used 7/16" or 3/8" socket. Can I get these at the hardware store?
Napa here carries theseThose particular bolts thread into u-nuts so I need them to match. I'm hoping I can just get them from the hardware store. Don't want to pay for shipping to get $12 OE type bolts from one of the parts companies.
