New ignition stuff is all in and running.
Went with a small cap HEI unit from eBay. All the regular Buick performance parts places were out of stock on distributors. I could have done a conversion on the points distributor, but this one gives me more advance tuning capability. The distributor included the plug wires which would be WAYYYYY better if I made them myself so the driver side isn't so absurdly long. It'll do for now.
So I've gotta explain why I wanted a new, tunable distributor. This thing has some crazy early smog timing setup. The system is called "Transmission Controlled Vacuum Spark Advance System". In essence there won't be vacuum advance until the transmission upshifts into 3rd gear (and technically Reverse also). When we swapped the transmission, I couldn't figure out why a 72 TH350 would have a wire plugged into it. That wire was connected to a solenoid in the hose to the vacuum advance that would either allow or restrict vacuum.
The vacuum advance is supposed to be connected to ported vacuum. Initial timing is spec'd at only 4° BTDC. The factory knew this could lead to overheating at idle so they had to add another system to compensate for that. I couldn't figure out what this doohickey on the intake manifold was and that's how I found out about this other system.
That is a "thermo vacuum switch". It has 3 nipples that are connected manifold vacuum, ported vacuum, and the distributor. If the coolant temp rose to 220° or higher, it would connect the distributor to manifold vacuum to increase advance and cool the motor down.
With all that Mickey Mouse, the factory distributor is setup to pull up to 20° of vacuum advance. According to the people over at V8Buick.com, I should be shooting for 30-32° of total timing at WOT all in by 2200 RPM. I felt like another 20° of vacuum advance on top of that at cruise would be way too much (50°+). If I'd converted the points distributor, I would have needed to change out the vacuum advance module too. That put the cost of converting the points distributor over the cost of the new one. Plus everything else is new too.
We've fired it up and locked in the timing. Ended up at 30° total and 12° initial. Just waiting on vacuum hose to show up so we can take it for a test drive. On the Street Demon carb, the manifold vacuum port is on the back of the carb and the ports directly to the manifold are behind the carb as well, so I need a good 18" of hose to get from there to the distributor at the front of the engine.
