400 so you can still drive it for a bit.
Just thinking out loud about the 400. I measured a cylinder and piston at lunch and it needs to go .020 over. Didn’t measure the crank or rods yet.
Also the boss for clutch linkage, is it as simple as drilling and tapping the boss on the block?
I planned on doing a clutch when the motor was out regardless but with the 400 being externally balanced id for sure need a new flywheel as well.
The clutch linkage bolts to the bell housing no? Flywheel you could get balanced, I`ve had one done for a 454 years ago. Do you have the harmonic balancer for the 400?
If the boss is there and not drilled, yes it's that simple. Most 2pc seal blocks should have it and be drilled though. Only thing you'll have to watch out if you drill it is going too deep.
Edit: If you happen to need a hand or parts, I may be able to help out. You're somewhat local.
