1972 K5 Blazer 408 SBC/700R4
yellow.dawg
Registered Member
Kokomo, Indiana
Pretty much a non frame off restoration. All work done withinthe last year. Still has a few flaws but its on heck of a Blazer. Original rockers etc in it. Only has had a small patch on driver floor cut and welded in. I have rhino lined the floors and bottom of the Blazer to help seal it from water and mud. Has a fresh 408 SBC (600 miles) that is dynoed at 310 HP and 420 LBS TQ and I have the build specs and dyno sheet. Has a cloyes gear drive, 9.6 to 1 CR, comp exreme 4x4 cam, stainless valves and on and on. I have over 3500 in the engine, has a new rebuilt 700R4 with .500 boost servo, 2-3 and OD extra hold servos from fairbanks, painless wiring kit for the trans. New 3 row aluminum radiator and dual fans, new heater core, new duel exhaust in 2.25 with stainless magnaflow mufflers. I just rebuilt the NP205 and rearend. Front has been rebuilt with balljoints etc a few years ago. Has brand new interior including rear side panels and restored seat belts, extra clean topper and hatch, brand new BFG 33 10.5 tires, new wagner brakes all the way around, new ranch shocks. Rides great and looks great with the 4 inch lift. I have a new NOS painted pass fender and quality gm outter grill shell as the fender is a goodmark and doesnt fit right. I just put a small dent in the tailgate last week, new topper seals and hatch lock. Drive this truck anywhere. Im asking 14K and my bank still holds the title as I owe some money still. Located in Kokomo Indiana, call 8158145822. Some seat belts still need installed as well some rear seat brackets.
More pics.. The engine pic is prior to completion. I also have installed a new 65 amp alt, new reg and new gold battery, has a rebuilt tilt column, new guage cluster with tach, restored seat belts in correct blue and new chrome, new alpine radio with cd and sat radio and a aluminum radio hold down. Very trick piece.
