K K5Greeality Registered Member Joined Oct 23, 2006 Posts 15 Reaction score 0 Location Greeality May 7, 2007 #1 Has anyone done this? And does anyone know if the pedal set from an 80 will fit? Thanks
clstolten 1/2 ton status Joined Sep 4, 2002 Posts 356 Reaction score 0 May 7, 2007 #2 I did this swap on my 74. Used a pedal set from an 80's truck, and it bolted in. Also, I was able to re use my stock crossmember.
K K5Greeality Registered Member Joined Oct 23, 2006 Posts 15 Reaction score 0 Location Greeality May 7, 2007 #3 Thanks...that helps. Did you swap out steering columns?
Jishory 1/2 ton status Joined Jan 8, 2002 Posts 1,366 Reaction score 0 Location Palmdale, CA May 8, 2007 #4 just make sure the bellhousing fits either your mechanical or hydraulic linkage
