I wasn't sure how it would do with the black, but it turned out nice.You know, normally I don't like wood grain in a vehicle, but for some reason you put it on a pistol grip shifter it looks cool.![]()
Yes. The window motor wires connect to the #30 terminal, and the NC terminal is ground on both relays. Then the NO terminals get the power, one at a time, to get the movement.One relay for up and the other down?
Yep.One relay for up and the other down?
Yes, that is the only way you can switch the polarity on the motor.One relay for up and the other down?
Exactly because it's literally flipping the polarity on the motor. It only has 2 wires.Yes, that is the only way you can switch the polarity on the motor.
I was looking at "bypassing" the lockout but I got to thinking about how easy it would be for my pup to fall into it and decided that was a bad idea.I can see it being annoying, but with where your shifter is located reverse lock-out is a necessary evil. I can recall many many years ago a V6 Vega I built, and used a junkyard floor shifter for the crappy TH200. Wasn't on the road two weeks when my girlfriend at the time accidentally knocked it into reverse while were doing about 35 mph. I went 4 speed shortly after...
From what I was finding you can't reach all the gears in an OD trans with the column shifter. Plus I've always enjoyed floor shifters.
I bought a nice OE aluminum one for my dads car that we put a 4L80 in, I got it from Summit. It was a Genuine GM cover.The way it's hacked up reminds me of the trouble I had with the dust cover on the TH350 when I tried to make it work with the 1 piece rear main seal engine. Makes me wonder if the dust cover on the 4l80 was replaced for some reason.
At first I thought you were implying I should do a 3-on-the-three figuring you were on the manual transmission angle. HahaHa, who told you that? They came from the factory with overdrive transmissions. The shifter just moves around. It has no detents. The detents are inside the transmission.
That's not me trying to convince you to use a column shifter, I was just giving you a hard time, but it would definitely work if you wanted to.
Martin
That's what I was thinking. I was wiping all of the grime off of it and I was trying to figure out why it was tearing up the rags so badly.That looks like a 350 cover to me that they cut
I'm just surprised someone bothered to put the effort in. I guess they did a better job than I did when I tried to make my old TH350 dust cover work with the new engine.You priced a new dust cover for a 4l80 recently? Suckers ain’t cheap.
I just found those. As much as I prefer that style, I'm already over budget a couple hundred dollars. I went down the rabbit hole of things you can improve in the valve body.I bought a nice OE aluminum one for my dads car that we put a 4L80 in, I got it from Summit. It was a Genuine GM cover.
