This is interesting. I was watching my intake air temps on Torque while I drove home from Denver. Consistently as long as the truck was moving at 20mph or better I was seeing 20-25° higher temp than ambient for the intake air temp. That's with the open cone air filter directly behind the core support with the 4" hole in it. If I came to a stop the IAT climbed to 100-105° with the ambient temp at 35°. I can only imagine what the split is when the ambient temp is 80-100° in the summer. Just doing some googlefu on the subject comes up with for every 10° change in IAT it equals a 1% change in horsepower in either direction. That means I was seeing as much as a 7% drop in power. In your case, you were leaving a little over 9% on the table with the open-element vs 1.5% with the cold air intake. That is provided that the 10°/1% rule of thumb is accurate for a naturally aspirated engine.I went back to factory TBI style air cleaner. Still had a little whistle with the cold air type setup and after seeing the decrease in air inlet temp, I'd rather put the cold air setup on the crew cab.
Bearing in mind the weather temps have been around 40°, here's the air inlet temps:
The core support in the 73 doesn't have an opening for the TBI tube so it isn't getting direct outside air, but neither was the cold air style. Also the air temp sensor on the TBI setup ended up being on the opposite side from the air tube, so it might read cooler if it was closer to the air coming in.
- Cold air type: 55°
- Factory TBI type: 100°
- Open element type: 136°
It certainly makes looking at an effective cold air intake a worthwhile addition to maximizing power and economy.
I believe the horsepower percentage numbers above might be correct, but I'll bet those are wide open throttle numbers. I bet the percentages might be smaller for lower throttle positions. Also like you mention, boosted vs n/a. I've mentioned before that Engine Masters did some dyno pulls testing different air intake temps and they inadvertently found that it was the fuel temperature that made the most difference. This was on a n/a engine, but also at WOT.
Previous owner welded angle to the battery tray, I assume to fix a corroded tray. He didn't make provisions for a battery hold down. So when I got the truck the batter wasn't held in with anything. I've found replacement trays for about $25 online, but I haven't pulled the trigger yet.
No bungie cords.
