I own the ‘73 with the full time option from the factory. I can’t stop my transfer case from leaking. Can i remove the front drive shaft and just run the back wheels? So I don’t have to keep adding gear oil all the time?
Yes, you can remove the front driveshaft and drive it without issues BUT that wont help the tcase leak.
If you decide to remove the shaft and it's still full time 4wd (not converted to part time) then you'll need to run the tcase in "HI LOC". Without the front shaft the regular "HI" position will send power to the path of least resistance (the missing front shaft) and the truck wont move.
I'm assuming the leak is pretty bad or you wouldn't have made this post. If you have to pull the tcase to reseal it you might consider adding a part time conversion kit to reduce parts wear and possibly gain a mpg or 2.
Btw, welcome! What part of Alabama? I'm down at the bottom.
With the np203 your choices are limited you can use a np205 but that is old too just stronger.Thanks for your help! I’m in Enterprise.
It leaks about a teaspoon a day. I had the best mechanic in town replace the rear transfer seal twice. He told me the seal the book calls for wasn’t even close, so he measured to locate the right seal.
Do you know if you can replace the whole system with late model stuff so parts aren’t an issue? Even if I could find an OEM tcase there would be no guarantees it wouldn’t be leaky too. I am also concerned something may be damaged/bent so no seal will seal up.
Thanks man
It’s a TH400. Does that mean I don’t have the 203?I'm a little rusty on tcase interchangeability. I'm assuming you probably have a th350 transmission, I think an '81+ np208 (with adapter and shifter assembly) will bolt up to your trans but you'd need to verify if the current trans tailshaft is the correct length for the swap - the 208 is a lighter aluminum unit that's very strong with a noticeably lower low range ratio (2.61 vs 2.0). Swapping to any tcase other than your np203 will force driveshaft length mods.
Sorry but the th400/203 was available in 73 and the 203 was the only tcase in 74Th400s were available in 4x4s starting in 1977. 77-79 were the only years to find a 400/203 combo. Most 400s had either a 205, 208, or 241, with the 203 being the rarest combo with the shortest output shaft. You could have a 203. Got a picture?
Every rear output leak i have seen was due to a groove worn on the yoke
I've had luck seating the new seal to a slightly different position, usually deeper. To move the seal lip off the groove
If the seal bore is damaged, it's not hard to fing 203 output housings.
Plus if you don't have a 2wd conv now, you could cheaply and easily throw that in while it's apart
YesWhen you do the part time 4 wheel conversion, do you have to replace the front hubs with manual lockers?
the heavy bastage though.
