1973 K10 : Chloe
1973 K10 offroad build
I didn’t get home till late today. Melinda was cooking so I asked if I could stay out to work on Chloe for a bit.
I got out the hydraulic ram truss mount and got it tacked together. The destructions are a bit vague, so, I just marked center on the ram, center on the truss, then kind of followed the picture.
I will burn in some of it tomorrow after I assure it fits in the axle correctly.
I’m about 75% finished with the welding.
Started in the center. Then used a come-a-long to pull the left side into where it’s supposed to be. Then did the same on the Right side.
I finish it tomorrow. I had to give the little Hobart 140 a break a couple of times. She’s pumping out all the voltage.
Finally, the fully welded ram truss mount and mounted double ended ram. The Clevises got an overtly healthy does of red loctite on the bolts.
Full hydraulic steering will go away completely if you shut the engine off. It’ll last a little while, but it will go away completely.
Martin
Martin
My understanding is that the load reactive orbital valve go into a neutral state allowing fluid to flow to which ever side valve is being forced.
Thus allowing slow “difficult”steering.
