Yes, i like to take the cap off and mark where the tip is pointing on the manifold and on the base of the dizzy so its all lined up, Also why I put mine in when I installed it because its a pain putting it in while the engine is installed, especially if its a few teeth off or something.
WHatever you go with just dont roll the motor over while its out so everything is set the same when you put it all back together.
