Sancho is living up to his name, just need to find some bailing wire holding something together to fully solidify the name.
I need to get under the truck and see WTF is going on. Looks like the frame was cut and another crossmember was welded in.
and the tailgate hinge is different so I need to source the older version and likely the limit straps. I never even knew the older trucks had different hardware until I went to install this tailgate.
then I see all these SWB 4x4 trucks on CL that can't pass smog for under a $1K and my mind starts running wild with cab swap ideas since Sancho is presmog.
