1975 K5 One ton part duex
1975 K5 + 1989 3500 C&C + 6.0
Step 1 - swap axles which means spring perch cutting and welding. One question...since this is a C&C axle when I swap to srw hubs tod make it full width does it change where the brake mounts on the inside? I think not but maybe otherwise the brake would be totally inboard of the wheel.
Step 2 - suspension, 52s up front. Back the based on junkyard finds
Ha, that is especially funny since I am from Quebec...
Love to hear some feedback on the 14bolt too...
Got a rear axle. I'll start grinding and cutting later today. The general plan is take the 63's, shakle flip in the rear and 52's up front...
5" of lift...ha. need a few more inches then start thinking about that front shackle angle. I've got some 6" tough country 47's but might have to go 52's or ?
Whats that rear disc brake setup on the 14 bolt, looks like it has an ebrake?
Dude...this site is dead;(
Factory disc brakes have the emergency brake inside the rotor, kind of a cool setup so if for some reason all the fluid goes away you can stop (or at least slow down)
Got one truck put back together and ready to go...anybody got a pic of a d60 passenger side mount? There is a big gap between the spring and the pumpkin...normal or bent studs?
The spring center pin sits in the center hole there and does not bend the studs.
I was waiting for parts so went snow wheeling in my other rig and had to do a little fixing over there. Im still waiting for a few more things, but cleaned up the frame a little, will put in a hatch since the gas tank is out and hopefully get the axle sorted out. Seems trivial, but figuring out what truck teh 14ff came out of was a little harder than I thought, but I needed that info to get the correct calipers, seals, etc...
normal BS, a little wire wheel, a little rust bullet and then a little paint
Put the tank back in and then looked through the parts pile in the back of my house and bam...found a gas tank cover! Also, threw in a hatch, started cleaning up the 14bolt and did some little things like fixing the cables etc... I'll need to figure out shocks soon, thinking 14" Bilstein 5125's, but open to suggestions
Where’d you get that hatch from? I’m about to pull my body lift off so I will need to install one.
