Guys I am still pretty new to this forum, I have been spending a lot of time reading through threads and such. I recently installed long tubes on my 1975 k5 during this I noticed a few Issues to correct before I start it back up. The wiring was jerry rigged pretty bad to the starter. I looked up the harness guides and trying to use my manual but I am still questioning a few things. what color or what wires should go to the starter/solenoid? i look to have a brown, black and yellow coming from that starter setup to the main firewall wiring block. Are these the three that should go back to run the truck? looks like the previous owners added a red jumper running from the starter to a factory bus bar next to the wire loom holder near the brake booster. Also looks like they had a black wire running from the negative on there down the passenger side to the fuel tank. Any direction with this would be greatly appreciated. I also removed an old red/blue combo wire that was running to the back that was cut anyone know what this would have ran in the original configuration?
