My gas gauge started slowly going toward empty and finally went way past empty while I was driving it the other day. It has a full tank of gas and I have grounded the wire for the sending unit with no change. I have taken the cluster out and checked all of the wiring and grounds. The weird thing is if you push the needle up and turn the lights on it quickly jumps back to below empty. I have checked all 3 terminals with my power probe and they all show to be grounded with key on or off. I ran another ground from the ground plate under the dash to the cluster with no change. Any help is appreciated. I did a google search for the wiring diagram and got everything except what I need.
