1976-1991 Chevy Blazer Full Size Bedside to Cap Weatherstrip Seal Set
I just ordered my set and I was about to install it. The question I have is what do you use to hold the seal in place? There is no two sided tape on the seal or glue of any sort. What am I supposed to be using?
Sorry just noticed this. They should install as the original seals did, if adhesive held them in place that should be used to attach them.
You can also call our tech dept at 888-844-3393
Hope this helps you out,
Tony
Thanks ! I ordered them Already ! I wish you gave CK5 .com members a Discount ? But on the Positive note cheaper then LMC and comes with a 10 year Warranty.
So this is the compete seal for top? I have a 88 K5 and the seals for the top look original and want a new set before i take it off.Thanks
yes and front doors/tailgate. Be sure to pull your vent windows out to check if one piece or two piece design. I can help you out if needed with this process.
Tony is a stand up guy can not say enough good things about him. Thanks again for helping me out and getting stuff straight. New seals came today and look perfect!
No problem at all, thank you for your order. I'm elbows deep in an 89 Wrangler project myself...lol
-Tony
We offer a lifetime warranty on weatherstrip unless noted.
