That could turn into who has the biggest junk yard around here...We need a "junk of the month" thread so I can enter my heap!..![]()
How much play is there in those bolt holes? I have this same problem with my 76.I have to ask. Do you know the trick to getting the hinges to pull the hood down?
Just loosen the rear bolts for the hinge on the fender a ways, then loosen the front one enough for the hinge to pivot on it. Lift up on the front of the hood, as to open it more, until the hinge rotates towards the cab. Tighten the bolts while holding the hood up. I would go just a little bit since you only need that small amount. It's possible to go too far with decent hinges and pull the hood too far down.
Hmm mine is probably a every bit of a 1/4. Never thought about that I could fix it that way. I might have to check it out.It seems like almost a 1/4". I know that the '72 and older are slotted some and I believe that the '73 and up are as well. (Memory loss...) I have done this adjustment on lots of them. It works well even if the hinges are fairly worn.
My problem is my aftermarket cowl hood. It's probably not as good as a factory hood to start with.I tried that trick on my 73, but it didn't help. It might have changed a little, but not enough.
It depends some on how good the hinges are. I got one to go from above the fender about an inch, to just right. If you have the hinge rocked all of the way, I would bet that the hinges are too worn. But it's possible to increase the slot length in the hinges too. Can even add some travel to the front hole in the hinge, but I believe that the main objective is to get the central part of the hinge downward. Make it do what you want!! Die grinder with a carbide bit.I tried that trick on my 73, but it didn't help. It might have changed a little, but not enough.
Not so must a trick but the way they designed the hinge. They are slotted to pivot around the front bolt when adjusting. I have this one set as low as it goes and it outs perfect on the driver side but slightly higher on the passenger side.I have to ask. Do you know the trick to getting the hinges to pull the hood down?
Yup. But I have had a couple of guys call it a trick when I showed them. Loosen bolts while they hold the hood, then tell them to lift more. I then tightened the bolts.. method, trick, same thing right?Not so must a trick but the way they designed the hinge. They are slotted to pivot around the front bolt when adjusting. I have this one set as low as it goes and it outs perfect on the driver side but slightly higher on the passenger side.
