Update:
Whelp, the shop basically fired the motor up back in November. Revved it, ooohhhed and awwed at the sound and could'nt get it to shift into 3rd. I advised them it's got a reverse manual valve bodied TH400 and told them it won't shift automatically!!! The next few days the engine builder went over to adjust the valve train. The result was water leaking from the exhaust and a cracked block. Apparently, water somehow leaked into one or two cylinders from the head and well the motor didn't like it. The shop insists it was caused by a sleeved cylinder as the engine was worked over once before. That's fine and dandy, however; the machine shop I took it to reassured me that a sleeved cylinder is common and not to worry. I figured it would be added security at least for one cylinder as it's already at .060. Anyway, the engine builder and machine shop have hashed it out and bored me out another block. It's in the process of rebuild and hopefully I wont get raped to hard on the price. This build is ummmm, yeah....
