Nicely done!
I would recommend using paint after sandblasting. Powder is not good in this type of application, or for outdoor corrosion protection, and will rust under the coating until it peels off.The powder coat was in decent shape but I gave it a decent scuff and quick coat of Rustoleum satin black to freshen it up for now. Plan is to get the powder coat re-done professionally sometime in the future when it's needed.
Great tip, thank you. I just assumed powder coat was the way to go. Any recommendations on brand/paint type?I would recommend using paint after sandblasting. Powder is not good in this type of application, or for outdoor corrosion protection, and will rust under the coating until it peels off.
Look up @ryoken posts for a paint guide here on CK5.Great tip, thank you. I just assumed powder coat was the way to go. Any recommendations on brand/paint type?
This would be coating for the swing-out tire carrier/bumper and the ORD low profile winch bumper I'm planning to get on order soon. How has the Dupont Nason stuff held up to the elements in your experience related to sun fading, etc.? I'd also expect these to take a fair amount of abuse on the trail. Considered RAPTOR coating both bumpers too but I don't have any experience with it, just like the idea that you can thin it out so it doesn't have a super textured look.missed it.. what are we coating here? raw steel? the standard automotive approach these days is epoxy with a 2k and topcoat.. or even a good uro over the epoxy.. most manny's have a decent economy line out, dupont, ppg, glasurit, etc, etc... well ok, there is no economical line with Glasurt $$$$$, but top O line... these days i run a ton of the Dupont Nason stuff.. damn good quality for the $$ IMO...
I was the huge zinc chromate guy around here for a long time, but the EPA has made that a lot more difficult these days, thus the epoxy recommendation....
as most here will attest to, I'm pretty ridiculous about proper prep... proper grit prep and cleaning between coating products is critical IMO for a long lasting finish......
Two great options here, appreciate the tips!Nasons pretty darn tough to elements, tho certain colors will sun fade over time.. which is normal... if you put clear over them, it alleviates that issue...
Raptor is good stuff ( Mutts dizzle tank is Raptor'd.... ) but I'm a BIG proponent of epoxy over the steel, than sand it for the Raptor.. not just straight Raptor...
