So you got an input shaft a page ago.
Martin
Martin
I put those same seats in my 79. They are nice. I would put them in the 76 but they won't fit the theme I am building that truck to.
As far as this farm truck goes. I think you should keep with the 70s look inside
No cheesey suburban wood dash, or seats etc etc.
Martin
When I'm done pulling out everything of value, that sort of horse trading becomes a distinct possibility. But those had better be some pretty fancy seats...![]()
10 minutes of drilling?
What happens if Mr. Murphy stops by to break your bit/tap? Or mis-locate a hole?
Maybe he doesn't know how you get to your house, but he stops by daily at mine...
Started disassembly of the suburban. Before I pulled the engine I checked the compression and ran it a bit to burn more of what little fuel was left out of the tank.
Compression numbers. Not astounding but this is a low buck engine swap for now, going to toss some gaskets at it and shove it in.
Compression numbers
Couple spark plugs were this way. How it ran smoothly like it did is beyond me.
Pulling the engine. Didn't feel like unloading it off the trailer. So I didn't.
And out on the stand awaiting its turn to be worked on. As clean as it is I'm curious if the dash reading of 71,000 is accurate and not 171,000 like I initially assumed.
Couldn't get to pulling the fuel tank. I think I'm Going to have to get torch bottles filled so I can torch off the receiver hitch and tank Skidplate. I may give it a shot with a cutoff wheel tomorrow. Since I can't get torch bottles until Friday.
Love the use of the company truck to pull the engine. Safety First!
Truly and honestly is the safest way to pull an engineI laughed at that. Serious overkill, but it gets the job done.![]()
Or at least that's my story and I'm sticking to it.
Ya know...I was about to ask if you had a skid plate on that parts truck. You wanna sell that, too?
Probably haven't used one in awhile, but when I was sorting tools the other day, this made me think of you being a Cat twister
Definitely jealous....
I used them for setting the fittings into hoses. I'm sure there are better uses for them than that. I ended up with -6 through -24
I'll see how big of a hassle it is to install after the tank goes in. I'd prefer to have it under the tank in the K20 but we'll see. If not it's all yours!
[QUOTE="78K30, post: 3781443, member: 69277"
[/QUOTE]
I have not measured yet, due to how far it hangs down in going to assume it's the big one. I'd prefer just a 31? Gallon tank but this one has a working sending unit and I already own it.
