1978 K5 "The Toilet" Evolution
LS or TBI, Please provide rationale in a comment?
  • Total voters
    11
  • Poll closed .
Yep definitely 99-04 Superduty, the front could be a 50 they used them in some trucks from 1999-2002 (I think)
It's def. a 60 front. Not a bad axle. Just have to switch to a t-case out of a 88-98 ifs truck for the driver drop.
Double check with your local LKQ Auto parts. I know there is one in El Paso. They may be just as cheap.
If it's a 99-04 I thought they only did a Dana 50 even in the F350 those years. it wasn't until 04+? that the Current D60 came back around. I'm not a Ford year break guru but I know that there is a series of years that the D60 didn't exist.
EDIT:
It's not too much if that's what you can find in your area. If that's a Ford 60 and is in running condition, with matching geared rear and a T-case that will work with your th350 and is drivers drop I think it's within reason, not a deal by any stretch for sure but if it's all matchy matchy and good I would look at it. I know you've been looking for a good while now as well.
99-04 had a Dana 60 in the F250's and F350's. The F250's also came with a Dana 50, but are honestly pretty rare. The 05+ are considered the Super 60. Larger inner C's and larger unit bearings. Also larger axle tubes blah blah blah.
All the dually trucks were 60s. It's a spacer that unbolts.
Both of my friends using super duty 60s have dually axles
Just an fyi, up here I sell that pair for $400 plus the t-case for $150.
Last year I went to a yard that had an abundance of newer Ford axles and no 8-lug chevys. They charged a flat $200 for any axle in stock. That's a bunch cheaper than the GM D60s typically go for, so I've been wondering since then how easily one of them could be utilized on one of our rigs. :thinking:
We have an early 99' F350 with 7.3 that has a D50, Every early superduty I have seen or been around has been a D50, so even if they were only an option they wern't that rare and in this case he needs to make sure it's a D60. I still don't think the first releases of the 99' to what might be 02' based on the below information had D60s. I swear Ford dropped the D60 axle from at least the single wheel line until sometime 02' to 04'.
http://www.fourwheeler.com/how-to/t...ord-super-duty-dana-50-to-60-front-axle-swap/
http://www.fourwheeler.com/how-to/1...akes-1999-2004-ford-super-duty-trouble-spots/
Don't forget anything in this year range and ford will be the new metric bolt pattern, 8X170mm? I think.
