1982blazer
I have a 1979 chevy c10 big 10 long bed for sale. 350 engine, good turbo 350 trans, 12 bolt rear 3.54 gears. I will throw in a western chasis 5" rear drop kit/ axle flip kit/ converting it to spring under axle, thus giving it 5" drop in the rear, it is made in the usa,I will also throw in all made in the usa. brand new moog pitman arm, idler arm, all new inner and outer tie rod ends, and all new moog upper and lower ball jionts. The truck does not run. It has a baaaad rod knock. The carb is off, and all thats left for the engine to come out is two bell housing bolts and the motor mount bolts, but i have all the parts. I have more than $300 dollars in parts alone. I have a clear texas title, and it has current inspection and registration stickers. I am tired of looking at this truck, i was gunna build a drag truck/hotrod. $300 or best offer takes it i want it gone
Edit: I also have 3" drop springs for it.
and all new timken wheel bearings
903-539-3149 is my number
.Edit: I also have 3" drop springs for it.
