Trans is bolted up to a engine, I need more light can't see anything!
Came in for the night was starting to get frustrated not being able to see.
Got light rechargeable headlight from Matco like so much bought 2. 1 for work other at home love some light.
I understand the headache. I've done a whole lot of my building via flashlight, it's just not nearly as easy when you can't see what you're doing.
Want talk about needing light. I once needed light so bad they threw a tripod light set up away at work due to legs broken and I took it home found a metal coffee can and poured concrete in it and let it setup. Still have it to this day for back up or driveway work if garage is full or use it to speed paint drying time up on smaller parts.
Home Depot has led lights thst plug into a socket and you can add another onto the existing light for 40 bucks. I want to add at least 2.
They work great. I've got four up on one side of the soffit in my garage. I've been needing to add a few more to the other side but hasn't happened yet.
