That would not cause vibration. Flat spots in the tires from sitting will. The Jimmy takes 50 miles plus to re-round the tires.
Vibrate with both hubs locked? Why is this?Front shaft should not rotate. Will vibrate with one or both hub's locked.
Not meant to run at speed. Both of mine vibrate over 45.
Lower the truckAny way to get rid of it? I just assumed it was my angle and lack of caster
Lower the truck
I bet it dint do this as a 2wd truck
Haha, it actually drives so much better now then when it was 2wd.Lower the truck
Tcase is in 2wd and hubs unlocked, guess it's just the nature of the beast.
Wow. You would think with Christmas so close, you guys would be s little nicer.
