Traded a buddy a ord banner for this tuffy console. The plan is to make brackets off my seat frame and build these side panels. This will house my radio, tcase shifter, ecu lights and USB plugs.
that was a solid trade
Man buns are bolt on. Just sayin
I would have to kick my own butt, high and tight always sense I was 12.
Just can't build the things I want to, instagram has spoiled this. I build it like 4 times before saying it's good enough.
Perfection stalls progress. Not everyone can do the kind of work some of the top guys around here. If you want perfection it's going to take time and a big tuition pile. If you want to use it, get it at least complete where it can be used. You can always come back and tweak and perfect things later.
Try to do the best YOU can do without trying to compare your work to someone that might have a higher skill level.
“Perfect” is an interesting thing. While often beautiful or elaborate, in a substantially high number of cases, it functions no better than something that’s direct and simple
In many cases, overthought and over engineered becomes the case, and the project never leaves the garage or even design stage. Lots of dead, over thought projects just wasting garage space.
Then it’s garage art
