I'm sure he'll be glad to help.
Rex gets under the truck with me and helps me lose tools and keep my face moist all the time :thumb:
Looks like the vintage air is coming soon, I haven't been out working on the truck. I got a dog and hes been taking my attention, I just don't want to leave him alone lol. He literally does nothing wrong, I just want to spend time with my friend. Soon I'll be doing some work and going back and forth from the garage.
He should be in the garage with you!
It is absolutely brutal outside right now. Even with my big evap cooler, the heat/humidity is kicking my butt.
My shop came with a large inop swamper, Didn't want that mositure in the shop so I removed it and capped the duct.
Two 2 ton mini spilts keep the shop nice. Both roll up doors are insulated, dual pane windows, 6" insulated walls
I've looked at adding an A/C unit to the shop, but I'd need to upgrade my feed from 200amps to 400amps before I did it and that requires running conduit about 400 feet under my neighbor's driveway and front/back yards. My shop is huge, but well insulated.
Yes the power issue was a close thing. a 50amp 240v volt circuit was sacrificed to power the minis.
I have 2 more 50s and 1 30, so it doesn't hurt that much. Only unusable in summer.
If outta the fireballs direct line of sight, a fan and cool bowl of water, he'll be fine. Just take breaks, good for the both of you.
Just don't go into a to cool place, high 70s low 80s will be refreshing, but not a shock to your system
Just used this on my K5 for the A/C to connect all factory stuff, Holley, and Sanden compressor.
Has all the wires to do IAC kick, AC shutdown, and pressure switch functions. Also works as the input for turning your fans on when AC is running if you want.
I thought about getting one of those but doesn’t the Holley do all that? Unfamiliar with that portion of it need to dig into it.
That's just a wiring harness for the Holley. It's just simplifying the hookup for you.
What reddog said. Its a harness that simplifies the connection from vehicle to Holley. Here is a picture that I followed for install. The rest are fairly self explanatory for connection. Pressure switch connection is not polarity sensitive.
