If it's not drive able by 2019 I got some serious issues...
Hey Ben, if you get a chance. Could you put your axle to full bump and get me a pic of the shackle angle?
I'm worried I didn't build my front shaft with enough room for full bump because I've only had my bump stops to about 3" compressed and the grease mark on my splines are about 3/4 from running out...
I'm hoping after negative arch it's actually reversing the shackle angle and pulling the axle forward. But I can't really just go check that...
My front driveshaft measured 4" of travel at full droop from static, and only 2" of travel on full bump... Which is confusing me as I was picturing the axle moving backwards only on bump...
is that a front mount hitch receiver? did you make that or buy it?
that tie rod looks stupid strong
nothing but overkill for the mall crawler build.
