Sorry, did not se the trail question. I have not signed up yet. I am the president of the procrastination club. I will run whatever Scott needs me to help on.
Does that mean I'm the founder? :haha:
And I was being serious about slotting the hood...
Ok back onto the frame plates still not clear on how to make then. Do I lay the plate over the weld of the shock hoops or does the plate go around the weld ?
My guess is that it would go around the weld so the plate can fit flush against the frame. Then just use multiple passes with the welder to connect the plate to the hoops. That's what I would do, at least.
Got the links, the axle brackets, the hoops all welded up today. Even made a new friend that will teach me to weld for beer.
:woot:
Looks good! Now put everything else together! The clock is ticking!
Going to put the 4 link back together this weekend, and get some plates made. I need a new pan hard bar or drag link. I swapped the ORD drag link to be the pan hard so the axle doesn't shift around on me.
I look forward to seeing this thing in Moab. :D
No pressure....
