The 4 link is ORD's the front rotors are stock? I just don't know what they are off of to get replacements.
I think you should stick with the 11" rotors or whatever they are now. I think you will be opening a can of worms to try to upgrade to some huge rotors for a 10 bolt front axle. Just wait and run the wheels and tires you have for now. That's what I would do at least. If you need more stopping power, try some stock sized slotted rotors and some EBC yellow stuff pads ($$$) and see how they do.
Rotors on the axle are 13 inch now...
I think we measured wrong. It was a rough start the other day.:haha:
Looks like 13 inches from here.:haha:
I wonder if the 8 lug rotors are bigger than the 6 lug ones or if they use the same size rotor and just a different hub. :dunno:
I figured it out....
We measure wrong and the catalog when it says 13 inch brakes is referring to the rear brakes. I assume the pad difference is the gvw stopping power.
That was a interesting morning for the both of us... Let's chalk it up to needed 5 hour shots.
It was probably me holding the stupid end. We were amazed it was magnetized.
The 8-lug front rotors are a touch bigger than the 6-lug rotors. Caliper backing plates won't quite swap. It's just enough different to be really annoying. :doah:
If your are using a 10 bolt front. You need 3/4 ton rotor and backing plate, the calipers are the same size. I have a GM parts book if you need the part #
Found rotors and pads. I think because we eye balled the tape measure our sleep state thought it was a half inch longer.
Thanks teck!
Sounds like a "thats what she said" moment........
Great work, hoping to see it rolling on the upper 4 tires soon rather than the lower 4 tires.
What do you mean by upper 4 tires?
Hoping to get some work done today, I have a back seat full of parts and fluids waiting to go on.:woot:
Gotcha, maybe this weekend we Can have brakes then shawns willys can pull me around for some hot laps.
