Was trying to use 1/4 because I had a sheet, would much rather use 3/16 But I would have to beg someone to get me some or pay a ridiculous amount. A 3x3 sheet was going to cost 80 dollars.What material were you using?
Nice job on the bumps!
No go on the wings for the bump cans my material was to thick and just isn't going to work. Not to mention I kept blowing up cut off wheels.
Where is everybody at? I start posting solid updates and everyone leaves haha
You can say that again1/4" should be no problem for those wheels, either 3/16" or 1/4" would be fine for that job.
Slow down and keep the wheel speed high, keep the wheel as shallow as you can if you need to make a turn. Otherwise they blow up really easy. I built my whole Blazer with a cutoff wheel back in the day, it can be done.
Trying to do this on a limited budget so I can fit more parts in.You know.....a plasma cutter would solve your problems.
We observe your frugality.Trying to do this on a limited budget so I can fit more parts in.
If you'd move closer, I could help you. The school district here is looking for qualified teachers and your employer has a branch 10 minutes from my house. And the house 2 houses down is for sale. 3 car, room for dog.Trying to do this on a limited budget so I can fit more parts in.
